GT2550 with 300 hours...tran flud never changed
   / GT2550 with 300 hours...tran flud never changed #1
Lead-Cons
Hi all
Got another GT2550 the other day used. The owner says he never changed the trans fluid. Other than that the unit looks to be in great condition. He maintained it well other than this issue. The tractor has 312 hours on it.
So, the question is, do I go ahead and change the trans fluid now? Somewhere I read that if it hasn't been changed, don't do it.
Thoughts? Ideas?
Thanks
Tom
   / GT2550 with 300 hours...tran flud never changed #2
owner's manual should give you the skinny on service schedule for tranny fluid/filter change. If you don't have the manual, get the tractor's full technical model number and serial number off the ID plate/decal located in the cavity under the tilting seat and going to URL PDF Manual Web Archive ..... enter requested data; d/l free manual in PDF format. Good luck.
So the fact that it has not been changed ever should not be an issue?
   / GT2550 with 300 hours...tran flud never changed #4
well, you can go ahead and depend on "somewhere i read" or follow the manual's schedule. Yer nickel.
Ouch...sorry didn't mean any offense
   / GT2550 with 300 hours...tran flud never changed #6
I would change the tranny filter and fluid
   / GT2550 with 300 hours...tran flud never changed #7
I'm not too sure about the 2550, but the lesser models (1000 series) usually have the TuffTorque transmission which is not intended to ever have the fluid changed (no drain/refill provisions). As you can see in the buzzillion-post TuffTorque thread, many have removed the transmission and figured out ways to drain and refill them, but with mixed results.
- Jay
   / GT2550 with 300 hours...tran flud never changed #8
Hi all
... Somewhere I read that if it hasn't been changed, don't do it.
Thoughts? Ideas?
Thanks
Tom
Well that's my usual rule of thumb on older OK running machines...leave well enough alone. But 300hrs is still kind of new and after a good warm up I'd change the fluid and filter with the right stuff. Close to 700 hrs on ours and it's on its second and final hydro change.
   / GT2550 with 300 hours...tran flud never changed #9
I would certainly change oil and filter, and then get back onto the 100-hour schedule. The machine may run with the old oil, but close tolerances and materials require clean new conditions, my opinion. You will drain out old oil, plus who knows what else, condensation, water, bugs??? Oil cheap, new tranny not cheap.
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A57880)
2014 PETERBILT 384...
KUBOTA M9000 TRACTOR (A57192)
KUBOTA M9000...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A55853)
2009 Mariah SC23...
3419 (A57193)
3419 (A57193)
2018 Lexus IS300 Sedan (A55853)
2018 Lexus IS300...
