GT2544 loose wheels
   / GT2544 loose wheels #1
Morkai
Tifton, GA
'05 Cub Cadet GT2544, HDS3165, HDS3225
After using my GT2544 yesterday I had a right rear tire go down as I was getting ready to park it. I probably ran over something, but while I was checking the tire looking for a leak I found that it seems to have some play when you grab it and rock it side to side. Anyone else noticed this? I checked the lugs, all tight, it didn't seem to be the axle itself. it's either in the wheel or the hub. I'll pull it off today to find the leak and look more at the hub. :confused:
Took the wheel off, found the leak. I was able to get a good look at the hub and axle. The axle does have about 1/16" or so end play, but the noise is coming from the hub that has about as much play. Is this normal and I just noticed it?
   / GT2544 loose wheels #3
Yep this play is a normal 2K series 'feature'. As you said, the fit between the bore on the rear wheel hub flanges and the turn on the rear axle shafts is a fairly loose fit. One hex head bolt and washer is all that attaches the whole rear wheel assembly to the axle shafts. As you've probably seen, the ends of the rear axles have flats machined on them as opposed to being keyed into the wheel hubs. What you want to do is remove each rear wheel assy and throw some never-seize on the ends of the axle shafts. It will quiet everything down and make rear wheel removal super easy in the future.
Joel
2017 INTERNATIONAL DURASTAR 4300 (A55745)
2017 INTERNATIONAL...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
Reel Mower (A55851)
Reel Mower (A55851)
CATERPILLAR CP-563D PADFOOT ROLLER (A52707)
CATERPILLAR...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
