GT2542 Seat Height Adjustment
   / GT2542 Seat Height Adjustment #1
vtcress
burlington, vt
GT2542 , broken YardKing
Got tired of having the seat tilted too far forward. Ground off 1 and 1/2 coils from the upper seat spring coils. Perfect now. Just passing the info along.
charlie in vt
   / GT2542 Seat Height Adjustment #2
good idea.
I notice myself that rarely is my back resting on the seat, my back is usually off the back of the seat because I am falling forward.
I'll take a look at that idea, sounds like a good one.
   / GT2542 Seat Height Adjustment #3
MrWiggles2 said:
good idea.
Isn't that the reverse of what you want? I have the same problem - I have to lean back to contact the seat back. If I shorten the springs, the seat will be leaning back even further.
Bob B.
   / GT2542 Seat Height Adjustment #4
I'm 6'4'' so what i did which is not pretty to look at,but works and has comfort I took a 10 gauge bar bolted to side of seat on both sides.and moved the whole seat mounting 3 1/2'' back as you see in the picture.and it lifts up and down as it should.the seat that is.
   / GT2542 Seat Height Adjustment #5
I posted another thread about this same issue. I'm also 6'4", and the standard travel is not enough for me.
Can you take a picture of what you did and post it? I might like to make the same modification.
Even with the wheel all the way forward, it's like a gymnastics exercise to mount/dismount and having a spine fusion with steel rods doesn't help.
-Larry
Use caution before deciding to cut as there are differences between the models and the years. For me (6 foot, 190 # and a GT2542 new this year) the solution was to remove 1 and 1/2 coils. I also noticed that on some upscale models, there is a plastic cap between the spring and the seat. If you cut too much off, that is a way of adding back. Its obvious that CC users would benifit from a more compliant seat adjustment system. My problem was that the upper back of the seat tended to push me off the seat or made me lean forward.
charlie in vt
   / GT2542 Seat Height Adjustment #7
hear are some ideas, spend some extra money and get the seating package for a 3000 series,or go to tractor supply and get a suspened seat,there is a heavy plate under the tin of the seat so if your good at tooling it would be no problem to fit that on yor cub pending where the gas cap is mounted on your tractor.
   / GT2542 Seat Height Adjustment #8
I'm 6'4", 310lbs. It ain't pushing me no where LOL
I need more REAR travel. Height is ok.
-Larry
charlie in vt
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55302)
Neckover GL24-2-7K...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A55787)
2006 Magnum 125...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
Jumper Cables (A53316)
2014 Ford F-550 4x4 Terex Hi-Ranger LT-40 40ft Insulated Bucket Truck (A55788)
2014 Ford F-550...
