GT2542 Hydro problem
   / GT2542 Hydro problem #1
zeke83
Little falls, NY
Cub Cadet GT2542
I just got a used GT2542 with 280 hrs...Thanks to snooping around this forum before I registered
I did a full service including replacing the hydro fluid and filter. I drained the fluid and replaced the filter, then I added 5 quarts of 15-40 rotella T. The dip stick said it was full, so I started the engine to circulate the oil and get a better reading. The problem is the tractor wont move now. When I press the forward or reverse nothing happens at all.
One thing I noticed is the lever to engage and disengage the transmission is not there...Must be it fell off on the previous owner??
Any help??
   / GT2542 Hydro problem #2
first off, make sure you replaced the tranny filter with an OEM type - substitutes/aftermarket types often have different internals and won't work properly in the tranny....
2) expect the other item discussed is the freewheel control? Personally, I would get that part replaced so that I could move the tractor w/o engine power in case of breakdown.
2019 John Deere 317G Track Loader (A50490)
2019 John Deere...
2019 FORD F-350XL FLATBED TRUCK (A50459)
2019 FORD F-350XL...
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
UNUSED 2025 CFG H15R EXCAVATOR (A50459)
UNUSED 2025 CFG...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
Husqvarna 128CD Weedeater (A48837)
Husqvarna 128CD...
