GT245 Seems Too Slow
/ GT245 Seems Too Slow #1
vonzip
Niagara, WI
John Deere X324
My GT245 has a 20hp Kawasaki engine and seems to run quite slow. Full throttle rpm seems slow to me. Is this normal? What can be done to speed it up a bit?
/ GT245 Seems Too Slow #2
Hello, welcome to TBN. "Seams" is a little subjective. I would first start by buying a tachometer. You should be able to buy one off ebay for less than $10. With it you'll actually know what speed your engine is running at and if it needs adjusting.
/ GT245 Seems Too Slow #3
Good advise. For now though you could verify that the throttle control cable hasn't slipped in the clamp and that you have full range on the linkage.
/ GT245 Seems Too Slow #4
I believe the foot pedals are adjustable for a little further travel. Under the tractor there should be a threaded linkage for adjustment. But if I remember correctly, the more forward travel introduced to the pedal, the less travel and slower the backup pedal will engage.
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
2011 FREIGHTLINER M2 112 CNG (A59909)
2011 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2022 Meridian 1375 Auger (A63116)
2022 Meridian 1375...
2014 CASE 590 SUPER N BACKHOE (A62129)
2014 CASE 590...
