GT235: Engine bogs way down/stalls out when engaging PTO
   / GT235: Engine bogs way down/stalls out when engaging PTO #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I think my post title describes the issue; I always rev the engine up to full throttle before PTO engagement but lately the engine stalls out. It takes 5 - 6 tries before success. Parts counter guy said possible fuel delivery issue? Looking for input, and thanks...!
I should add that I have bypassed the seat switch. Also, if I use the choke I can prevent the engine from stalling out when engaging the PTO.
   / GT235: Engine bogs way down/stalls out when engaging PTO #3
Sounds like fuel delivery. The engine is gas powered? Not fuel injected?
I never engage PTO at full throttle. Always just enough engine speed to avoid stall. Really hard on your tractor and/or the attachment doing full throttle engagement.
   / GT235: Engine bogs way down/stalls out when engaging PTO #4
Just use the choke.. if that works.. it does for me when engaging the PTO on my 425 when the mower deck AND the power flow blower are both connected AND the engine is cold. Once warmed up, no problem.
   / GT235: Engine bogs way down/stalls out when engaging PTO #5
Could be fuel but also the governor. Might be dirty or binding and not responding fast enough. Check the linkages and springs. Try some good carb cleaner before you do anything.
   / GT235: Engine bogs way down/stalls out when engaging PTO #6
Yes an ounce or two of Seafoam in the fuel tank with some fresh fuel and before you know it it will be less finicky.
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
Towable arrow board (A55973)
Towable arrow...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
(3) 2000 LB FLIP UP TRAILER JACKS (A57192)
(3) 2000 LB FLIP...
Jack Daniels Miniature Decorative Truck (A55853)
Jack Daniels...
