GT235: Deck stuck in position
/ GT235: Deck stuck in position #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Last time I used my garden tracor I pulled the deck raise/lower lever up for transport and felt/heard something that did not sound right. At that point the deck was "frozen" in position - I had no height adjustment or response from the deck when I moved the lever. I removed the deck today, and was able to rotate the height adjustment knob again and so I figured all was good. Upon reinstalling the deck - same issue. Looking underneath the right side of the fender, it seems to me that the cam that is attached to the deck height knob is contacting the piece of metal (see attached diagram) which is attached to the lift assembly, preventing it from moving. Any thoughts on fixing this?
/ GT235: Deck stuck in position #2
Suspect you have slipped over the top of the pin that holds the deck from bottoming further. Happens, and think you are close to figuring out what to do for a fix.
I'm not sure. I jacked up both sides of the mower deck and the height knob turns freely, allowing adjustment. As soon as weight is supported by the tractor lift mechanism the deck is once again immovable.
/ GT235: Deck stuck in position #4
Lift mechanism is under the height knob, not above it. (my guess)
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2021 Bobcat T770 (A64911)
2021 Bobcat T770...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A66736)
2015 International...
