GT1554 Use automotive type fog lamps?
   / GT1554 Use automotive type fog lamps? #1
philw
I'm really disliking the headlights on my garden tractor.
Would the electrical support the removal of the stock bulbs and sockets, and replace with automotive 55w driving lights? I was going to fab a bracket, pull out the sockets and front clear plastic lens, and mount them there.
   / GT1554 Use automotive type fog lamps? #2
They don't put good bright lights on tractors now a days like the sealed beam headlights my old 66 Bolens has.
   / GT1554 Use automotive type fog lamps? #3
If the lighting system doesn't have a relay then you should add one. If your buying new driving lights buy a kit that has the wiring and relay kit with it.
   / GT1554 Use automotive type fog lamps? #4
I doubt the factory wiring to the front is large enough for that current draw. You could run your own larger gauge wire and use a relay off the factory wiring as suggested. I would run it straight from the battery to the relay with it's own inline fuse.
   / GT1554 Use automotive type fog lamps? #5
I wouldnt use the 55wt auto fog/driving lamps, but would recomend a pair of the round sealed beam lamps you can get thru either wal mart or TSC/Rural King. They use the same basic sealed beam flood lamp that the older cubs like mine use. The mount the same way as a driving light does, and the lamps are shock mounted in the rubber housing to prevent them from burning out so easily. Here is a pic of my wife's 582 Cub Cadet with one of those lights facing rearward. Cheers Mike
   / GT1554 Use automotive type fog lamps? #6
Did you already get this resolved? Another option which is very simple and brightens up your output is to replace the 1156 auto lamps with halogens.
I was looking to improve the lights in my CC 3184 and went to NAPA. They have a # 795 lamp that fits in the same as the stock 1156. I believe they are 50w and when I switch them on the voltmeter gauge changes while running from about 13 to 12.25.
They aren't a focused spot, more like a flood - but a very easy job to do. If I wanted to do more, I'd consider rectangular halogens from TSC (about $15 ea.) and weld them to the 1/4 inch steel front bumper. They were $9 each and worth it to me. I checked several other parts stores and no one else had such an item.
Cheers!
Kent
2020 DRAGON ESP...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2012 Ford Explorer (A53317)
2012 Ford Explorer...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
2012 Ford F-550 Landscape Dump Truck (A55852)
2012 Ford F-550...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
