GT 3000 steering
/ GT 3000 steering #1
Mattmotors
Massey Ferguson 2310 TLB
Hi all, I have a Sears Craftsman GT 3000 (917.275042) with a 23 hp Kohler. I have a steering problem where I can make a real sharp left turn , but my full right turns are real wide. I can't find any adjustment to center the tires when the steering wheel is in the center (straight) position. There are adjustments on both wheels but they are to keep the wheels parallel with each other. I'm going to guess that the steering control rod that connects the steering wheel to the tires is bent thus allowing sharp lefts but wide rights. Can anyone help me confirm this or advise me? Thanks , Matt.
/ GT 3000 steering #2
Just a thought, but if you disconnect both tie rod ends, straighten the wheels, and center the steering wheel, can you adjust the linkages enough to go back together?
/ GT 3000 steering
It 's not like other tractors. I tried it , no deal.
/ GT 3000 steering #4
They are designed this way. I guess it is assumed because the discharge is on the right you will be turning left most of the time. My GT 5000 is set up the same way.
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2011 Ford E-250 Cargo Van (A64556)
2011 Ford E-250...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
