GT 275 hydrostat problem
   / GT 275 hydrostat problem #1
bkussatz
John Deere GT275
I have a 1996 GT 275 with Hydrostatic Tansmission. When I step on the forward pedal it will drive very slowly. Reverse does not move at all. One thing I did notice is that my Free Wheel- the linkage that you pull when you want to push pull or tow it- will pull out but I am not able to push or pull the tractor. Does anyone know what might have happened. I appreciate any help that could be given.
   / GT 275 hydrostat problem #2
I would first check the route of the linkage, to ensure it is not hanging up, or binding, I would also change the hydro fluid if you never have, and check if there is a filter to replace or clean. Sounds a bit like starving for fluid. Keep us posted on what you find. Also give the entire hydro trans a good blowing off with compressed air, and a possible washing, so that all the proper cooling that can be available is there. Dirt, and grass are insulators....:D
   / GT 275 hydrostat problem #3
If the free wheel linkage got pulled out you may have some air in the tuff torq. The valve is also used to bleed air out of your hydro. Here is a link that will help
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/TechInfo/docs/AirPurging.htm
Also everything in the above post. The bleeding out the air has happened to me and a few of my friends also
   / GT 275 hydrostat problem #4
MOST SIMPLEST REPAIR TO DATE!
I know this is an old thread, but these threads do come in handy.
Grab the foot brake and pull it back about an inch, problem solved!
UNUSED LANDHONOR ARTICULATING BRUSH CUTTER (A50460)
UNUSED LANDHONOR...
2010 Chevrolet Silverado 3500 Utility Truck (Diesel), VIN # 1GB7CZB60AF108861 (A48836)
2010 Chevrolet...
UNUSED Brown Metal Roof Panels (A50860)
UNUSED Brown Metal...
2017 Ford Explorer Police SUV (A48082)
2017 Ford Explorer...
Kubota SVL92-2 High Flow Cab Skid Steer (A50397)
Kubota SVL92-2...
12ft Stainless Steel Livestock Panel (A48837)
12ft Stainless...
