GT 275 hydrostat problem
/ GT 275 hydrostat problem #1
bkussatz
John Deere GT275
I have a 1996 GT 275 with Hydrostatic Tansmission. When I step on the forward pedal it will drive very slowly. Reverse does not move at all. One thing I did notice is that my Free Wheel- the linkage that you pull when you want to push pull or tow it- will pull out but I am not able to push or pull the tractor. Does anyone know what might have happened. I appreciate any help that could be given.
/ GT 275 hydrostat problem #2
I would first check the route of the linkage, to ensure it is not hanging up, or binding, I would also change the hydro fluid if you never have, and check if there is a filter to replace or clean. Sounds a bit like starving for fluid. Keep us posted on what you find. Also give the entire hydro trans a good blowing off with compressed air, and a possible washing, so that all the proper cooling that can be available is there. Dirt, and grass are insulators....:D
/ GT 275 hydrostat problem #3
If the free wheel linkage got pulled out you may have some air in the tuff torq. The valve is also used to bleed air out of your hydro. Here is a link that will help
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/TechInfo/docs/AirPurging.htm
Also everything in the above post. The bleeding out the air has happened to me and a few of my friends also
/ GT 275 hydrostat problem #4
MOST SIMPLEST REPAIR TO DATE!
I know this is an old thread, but these threads do come in handy.
Grab the foot brake and pull it back about an inch, problem solved!
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Towable Air Compressor (A64553)
Towable Air...
