GT-2550 PTO Switch - All Fixed?
/ GT-2550 PTO Switch - All Fixed? #1
rau2009sch
Monett, MO.
Cub Cadet GT 2550
Could not get switch removed yesterday, a new one was $25, so I tried PB-Blaster. Sprayed it on terminals, inside the switch, under the push-pull knob, all around, inside and out. Seemed to push-pull much more freely, ran just fine and energized the clutch yesterday a dozen times or so.
I think the PB removed dust and dirt, removed corrosion, stopped corrosion, lubed everytihng. Seems to work now.
/ GT-2550 PTO Switch - All Fixed? #2
are you washing that tractor with hose or pressure washer? If so, quit. Use air hose or leaf blower to get rid of trash after each use and then just a good minimal soap/water wipedown followed by a good waxing once or twice a season - good to go. L&G powered eqpt is not designed/built to withstand getting wet. Electrical systems are particularly vunerable. Chk yer manual.
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Water Tank (A62613)
Water Tank (A62613)
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
1974 Transtar 4300 Roll Back Truck (A65563)
1974 Transtar 4300...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
