GT-2550 PTO Switch - All Fixed?
/ GT-2550 PTO Switch - All Fixed? #1
rau2009sch
Monett, MO.
Cub Cadet GT 2550
Could not get switch removed yesterday, a new one was $25, so I tried PB-Blaster. Sprayed it on terminals, inside the switch, under the push-pull knob, all around, inside and out. Seemed to push-pull much more freely, ran just fine and energized the clutch yesterday a dozen times or so.
I think the PB removed dust and dirt, removed corrosion, stopped corrosion, lubed everytihng. Seems to work now.
/ GT-2550 PTO Switch - All Fixed? #2
are you washing that tractor with hose or pressure washer? If so, quit. Use air hose or leaf blower to get rid of trash after each use and then just a good minimal soap/water wipedown followed by a good waxing once or twice a season - good to go. L&G powered eqpt is not designed/built to withstand getting wet. Electrical systems are particularly vunerable. Chk yer manual.
