gt 245 kawasaki prob
   / gt 245 kawasaki prob #1
jimbo64
Im having trouble with my jd mower- when i shut it off, it will not restart----pulled air filter and found about 1/4 inch of fuel laying underneath it- soaked it up with a paper towel, left it set about 20 min and it started right up-----has new sparkplugs, air filter, fuel filter------did this a couple times last summer also-20 hp twin cyl Kawasaki, has 600 hrs on it, bought in 2002 i think. Carb is preset a factory and book says no adj there-------any ideas on where i need to be looking would be appreciated. Afraid the whole thing will catch fire----------------------Jimbo
   / gt 245 kawasaki prob #2
I have a GT 225, Kohler 16, so it's a bit different. Is the air filter lower than the carb? Almost sounds like your carb is leaking some. You might need a rebuild kit. I also have a 325 and the filter is on top. strange that the fuel is going UP?
thanks for reply---could be carb leaking -more investigation needed i guess----gas not in airfilter but laying below it------------j
Im having trouble with my jd mower- when i shut it off, it will not restart----pulled air filter and found about 1/8 inch of fuel and engine oil laying underneath it-[ right in front of the butterflys]- soaked it up with a paper towel, left it set about 20 min and it started right up-----has new sparkplugs, air filter, fuel filter------did this a couple times last summer also-20 hp twin cyl Kawasaki, has 600 hrs on it, bought in 2003 .Carb is factory and book says no adj there-------any ideas on where i need to be looking would be appreciated. -there is a clear vent tube coming off carb- tried to blow through it [mouth] couldnt do it---tipped it up and filled with carb cleaner, let it sit overnight and tube still full today------shouldn't i be able to blow through it an shouldnt fluid drain down? thanks guys-bear with me- i'm learning
update------------
2020 KUBOTA RTV...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
2006 Brush Bandit 200UC Towable Brush Chipper (A52377)
2006 Brush Bandit...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
