gt 245 kawasaki prob
/ gt 245 kawasaki prob #1
jimbo64
Im having trouble with my jd mower- when i shut it off, it will not restart----pulled air filter and found about 1/4 inch of fuel laying underneath it- soaked it up with a paper towel, left it set about 20 min and it started right up-----has new sparkplugs, air filter, fuel filter------did this a couple times last summer also-20 hp twin cyl Kawasaki, has 600 hrs on it, bought in 2002 i think. Carb is preset a factory and book says no adj there-------any ideas on where i need to be looking would be appreciated. Afraid the whole thing will catch fire----------------------Jimbo
/ gt 245 kawasaki prob #2
I have a GT 225, Kohler 16, so it's a bit different. Is the air filter lower than the carb? Almost sounds like your carb is leaking some. You might need a rebuild kit. I also have a 325 and the filter is on top. strange that the fuel is going UP?
thanks for reply---could be carb leaking -more investigation needed i guess----gas not in airfilter but laying below it------------j
Im having trouble with my jd mower- when i shut it off, it will not restart----pulled air filter and found about 1/8 inch of fuel and engine oil laying underneath it-[ right in front of the butterflys]- soaked it up with a paper towel, left it set about 20 min and it started right up-----has new sparkplugs, air filter, fuel filter------did this a couple times last summer also-20 hp twin cyl Kawasaki, has 600 hrs on it, bought in 2003 .Carb is factory and book says no adj there-------any ideas on where i need to be looking would be appreciated. -there is a clear vent tube coming off carb- tried to blow through it [mouth] couldnt do it---tipped it up and filled with carb cleaner, let it sit overnight and tube still full today------shouldn't i be able to blow through it an shouldnt fluid drain down? thanks guys-bear with me- i'm learning
update------------
