GT 242 Trouble
   / GT 242 Trouble #1
Brack
Green Bay, WI
JD 2210
I've been handed a problem with my sister's GT242 and hopefully someone on here can point me in the right direction. The tractor starts and runs fine, but if you operate it for some time and then shut it off it won't restart. It turns over fine, but it just doesn't fire. If you wait 60+ minutes it will start with no problem. This happens in both warm and cool weather. Thanks in advance for any insight you can provide.
   / GT 242 Trouble #2
If it was me in the same situation...
First thing I'd do when it wouldn't start is to make sure it had a blue spark to the spark plug (take it out and ground it) . Second I would check the plug to see if was getting gas (you can do this at the same time). Once you do these two things you can narrow it done significantly.
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
Rubbermaid Water Trough - 100 Gallons (A55218)
Rubbermaid Water...
SDLANCH ELECTRIC GOLF CART (A53843)
SDLANCH ELECTRIC...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
GENIE MANLIFT GR15 (A53843)
GENIE MANLIFT GR15...
