HEC
Veteran Member
I went to look at tractors and they didn't have a gst tractor I could try out.The kubota rep. was there and said I should probably go with a gst as I do some plowing .I only talked with him for a couple minutes as he was quite busy.I still don't understand all there is to the gst trans. except that it does the clutching for you.Does it have a clutch peddle ,if so when do you use it?Does it have a shuttle type lever on the steering column for forward and reverse for doing loader work?I am interested in the GL5030 tractor that I want to use with a snow blower on the rear also, so the hst would be ideal for that.I do loader work and lots of mowing,tall heavy grass mostly with a bush hog.I have an m5400 now that I am selling as I can't use a snow blower on the rear as it backs up way to fast,no creeper gear kit available for it.
Any help would be appreciated,
Thanks,
Herb
Thanks,
Herb
