das295
I've got a GS 6500 with a 26HP Kohler Pro. A week ago had mowed a portion of the yard and shut down the tractor to refuel. Tried to start and would turn over but not fire. Let it sit for awhile, fired back up and continued mowing with no problem. Couple days ago my wife is mowing and I hear the tractor cutting in and out and also find that when the deck is engaged any mowing will bog down the engine significantly. Took the deck off, cleaned and checked spindles which seemed to rotate fine. Ran the tractor without the deck and it did ok but I can tell it is not quite full power and it still has a faint cut-out in the sound of the engine. Cleaned the carb, and checked the fuel shut-off solenoid which seemed to be working (can hear it click when key turned to run). Checked the vacuum fuel pump and it puts out fuel when the engine is cranked (although when I stopped cranking fuel continued to flow until I finally clamped the hose; guess I figured it should eventually run dry on the carb side of the fuel pump once the cranking stopped). So at this point I'm not sure which way to go to find the actual problem. You guys have any ideas on where I should be looking? Thank you for the help!
