beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,529
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
I think one is asking for some 'real hurt' if using a nylon rope to pull anything out where the rope might break. Too much energy stored up in the nylon and there is a long history of injuries and deaths attributed to what happens to that energy when the rope fails.
Better to use chain or cable. In my opinion. Much safer.
There are ropes now with high strengths and no energy buildup as they don't stretch like nylon.
Clearing fence rows is bulldozer work that can be done with CUT's with hoes' and toothed buckets. If time isn't critical, then there can be some good seat time using a CUT. But the CUT's are usually not well protected from falling trees, brush, and tanglements of brush, sticks, and limbs on the ground. Can poke at every hyd. hose, the radiator, and the electrical wiring. As long as the CUT isn't used like a bulldozer, then it should work without too much damage.
