Growing Horseradish
   / Growing Horseradish #1
DocHeb
Veteran Member
Michigan
New Holland TC40D Supersteer
I would like to grow a "little" horseradish, but from what I've read this may be difficult since the plant is so prolific. My usual online seed/plant sites sell packs of 5 roots for $$, but I think that may be 5 family's lifetime supply.
If I bought a single root from the grocery store, do you think it will grow?
   / Growing Horseradish #2
Not sure, It may, if not check out nourse farms, i bought some blackberries and asparagus from them and can rate them A+. I think they also sell horeseradish and they have a section on growing it.
Not sure, It may, if not check out nourse farms...
That's the site I was looking at - 5 roots for $10. Not being cheap, but with shipping ~$6, I considered it and initially discounted it. I may end up going there. Thanks.
   / Growing Horseradish #4
Find someone that has it allready, be nice, and more then likely they'll give you a few roots to start. I just got 12 roots from a friend. He is having folks dig a bunch because it spreads like wildfire. My last plants I got from a co-worker{at the time}, I buried them while digging out my pond:mad::(:drool:. They grew quick and were huge.
   / Growing Horseradish #5
The trick for a nice horse radish is to give it bottom. Dig a hole, cover the bottom with big tile or bricks, fill it up up and plant. The theory is that the root stops growing down and grows thick.
   / Growing Horseradish #6
I've seen horseradish roots somewhere like WalMart or one of the big box stores, probably in the same area where they had bulbs and stuff. I bought mine a few years ago from one of those cheap nurseries that advertise in magazines. Be sure to plant it where you want it. I planted raspberries too close to mine and now I have raspberries in the horseradish and vice versa....should make an interesting salad dressing.
Grinding your own fresh horseradish is a treat. Especially if you happen to have a stopped up nose. If the smell doesn't open your sinuses, try a teaspoon of the fresh stuff.
Chuck
   / Growing Horseradish #7
The secret to keeping horseradish under control is NOT to run a rototiller through it. Every piece that breaks off will grow. My grandson and I dug over 100 roots out of our garden last fall and sold them to someone wanting to grow horseradish as a cash crop. The 100 roots came from the the 3 or 4 roots that SOMEONE ran over with the rototiller several years ago.
   / Growing Horseradish #8
Ouch it sounds like bamboo. Might be a good container plant
   / Growing Horseradish #9
Cut the bottom out of a 5 gallon bucket, dig it in flush with the ground, & plant inside the bucket. Or cut some 18" rings from plastic 55 gallon drums & plant the same way. MikeD74T
   / Growing Horseradish #10
I don't know where in the Mitten you are, but folks around here just give you a chunk. Take a shovel and split off a root. Water it and it is fine. I got enough. If you're close enough, stop by and get some. Kinda like rhubarb.
2018 Dodge Journey SXT Van (A42744)
2018 Dodge Journey...
2016 Vermeer TLR33 8ft S/A Trailer (A42742)
2016 Vermeer TLR33...
2012 UTILITY VS2RA 53FT REEFER TRAILER (A43004)
2012 UTILITY VS2RA...
PALLET OF SAFETY FENCE (A45333)
PALLET OF SAFETY...
2009 Ford Econoline Van, VIN # 1FDWE35L99DA49733 (A44391)
2009 Ford...
295 - 5952 CAT Bucket 24in (A44391)
295 - 5952 CAT...
