Grow lights
/ Grow lights #1
Molerj
Platinum Member
Eastern Ohio
JD 955, 1978 Economy Power King, JD X500
We would like to try to save some of our flower plants ie; ferns, habiscus etc. over the winter. I have an 10X30 unfinished, unheated area that we use for storage under the front porch. It has block walls, plywood floor (decided to use the space after the house was built) & is accesible from the basement. . Altho it gets cold, it doesn't freeze. We are only interested in keeping the plants alive through the winter. Suggestions?
/ Grow lights #2
A heat source and standard four foot fluorescents will be the cheapest option.
/ Grow lights
Thanks for taking the time to respond;
would heat be necesary, we just want to keep them alive, dormant.
Would standard flourescents be ok or should we buy the special flourescents?
/ Grow lights #4
You do want the special grow lights; not the standard florescent. I got mine at Walmart. I'm not sure about your temperatures though. Where my wife has her plants, it's not likely to get below about 50 degrees.
/ Grow lights #5
I live in Florida and we lost plants last year that were in the garage, I would say that if don't have heat than you might get by if you if try and trap the heat from the lamps with insulation.
/ Grow lights #6
I found a study on the Internet, ten years ago at this point, that showed the color output of the special grow lights had less of the spectrum you wanted than the standard lights. I forget all the details but after that I didn't waste anymore money on the special ones. And haven't noticed any loss from it.
/ Grow lights #7
Use a double 4 foot fixture with one cool white tube and one warm white tube. This will give you full spectrum. The light intensity will be too low so keep the fixture within a few inches of the plants. Tropical Hibiscus (H. rosa-sinensis) can be maintained over winter at about 40F. be careful not to water much as you will rot them.
/ Grow lights #8
something that may be being overlooked is proper ventilation...plants need a steady flow of fresh carbon dioxide...at the very least a circulation fan would be needed in an inclosed structure and some venting if the room is tightly sealed...
/ Grow lights
Thanks for all the suggestions. I have a bunch of shop lights that I replaced with 8' cold weather flourescents in my big garage so I can rig up something. Ceiling height is only about 6', so maybe enclose an area with a few sheets of plastic with the lights overhead. I'll check out the flourescents at Walmart, Bird.
/ Grow lights #10
We use fluorescent plant gro lights like some of the others. Make sure the plants get watered properly. Just because they are dormant people forget about water which is a big boo boo.
Good luck, I hope they do well and you can save your plants and some money!
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2006 CATERPILLAR 232B SKID STEER (A64279)
2006 CATERPILLAR...
213121 (A64276)
213121 (A64276)
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
ONAN 6.5KW GENERATOR (A64281)
ONAN 6.5KW...
