GroundMaster 223D PTO shaft removal
   / GroundMaster 223D PTO shaft removal #1
phrankndonna
Toro GroundMaster 223D
Hello. I've posted this question to My Tractor Forum (URL: GroundMaster 223D PTO shaft removal), and I've had a few dozen looks but no responses, unfortunately, so I'm reaching out to other sites. I've got a terribly worn PTO bearing bracket assembly and bushing plate-support that I need to replace. Problem is getting the PTO shaft out. It seems I need to remove the whole PTO shaft to replace these parts, but I'm not sure what all needs to be done to do that.
I've got screenshots below, including a parts diagram in the last picture, that show the issue.
There is a bearing collar-lock (part #16 on the parts diagram picture) on the front side with a set screw. The only way I can see to loosen that set screw is to remove the gas tank. Am I wrong (I hope!)?
And is that all that needs to be done? Does the back end of the PTO shaft also need to be removed (part #1)?
Thanks for any advice! Also please let me know if anyone knows of another place where I might find an answer. Thanks!
PTO bracket (front looking back)
Automotive tire Motor vehicle Automotive fuel system Automotive exterior Gas
Worn PTO bracket picture #2 (front looking back)
Gas Motor vehicle Automotive fuel system Automotive exterior Auto part
Worn PTO bracket (back looking front)
Automotive tire Gas Rim Auto part Automotive wheel system
PTO shaft parts diagram
Slope Font Parallel Triangle Pattern
   / GroundMaster 223D PTO shaft removal #2
Can't tell from where I'm sitting if you have to remove the tank. :cool: You will have to remove the PTO driven shaft from the PTO shaft at the U-Joint (#17). Once that's off, you should be able to loosen the collar set screw, turn the collar and remove it from the flange bearing. Not sure why you would need the bracket (#12) and #13 looks like it's just flat stock. Some time at a drill press will make that. The flange bearing and collar could be off the shelf items if you have the size. The one shown in the link is 1 3/8".
THANK YOU for your reply! I've been sitting on this for a bit, not wanting to do more than needed. I've got a backup mower, but I miss my 223D! I've already got the parts, so it's just a matter of getting the PTO shaft out to replace them. The way I'm seeing it, though, is even if I remove the U-Joint, the PTO shaft is still extending through the PTO Bearing Bracket (#26), the Bushing Support Plate (#64), and the PTO Shaft Bearing (#23). Do I have to remove the bolt and washer (#14, 15, 16) to completely release the PTO shaft and pull it through?
Again, thank you very much!
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
