Ground Smoother: Just add chains!
   / Ground Smoother: Just add chains! #11
I think what they were trying to say, is if you hit a buried obstacle, such as a rock or root, your tractor may pull the mesh out of place, or worse, such as bending the whole tailgate out of square. I agree that the sand we have here would do most of my tailgates some good if I would follow up with a quick primer and paint, but my tractors would probably bend them all up with the horsepower they have. A smaller tractor might not be hard on it.
I think a good rule of thumb might be that if you can drive your tactor up on it, it probably won't hurt to pull it thru the dirt with it.
David from jax
I was talking about final smoothing on known loose dirt, not levelling or grading.
The final drag.
   / Ground Smoother: Just add chains! #13
Shucks, I was hoping a bunch of people were going to start clearing some property with their tailgates, cause I was fixing to run down and invest in "tailgate stock", so I could be on the ground floor when this word about this post got around.
David from jax
   / Ground Smoother: Just add chains! #14
I've smoothed my driveway out several times when I forgot to put the tailgate up. Gets pretty noisy once you hit the paved road.
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
