ground plow
/ ground plow #1
drz400
Upstate New York
'05 JD 3320
Hi all!,
I have a JD 3320 (33 hp.) and I want to get a ground plow.The plow I have in mind is a 16" 2 bottom Ferguson. My question is does my tractor have enough h.p. to handle a plow of that size? Thanks.
/ ground plow #2
Yes.
Rule of thumb is 12-15 hp per bottom. Depends, too, on the ground - heavy clay/light sand - and size of bottoms- 12, 14, 16".
But you should be ok.
Wm
/ ground plow #3
You should be OK. I have a 29hp Kubota, and I bought a 2bottom Dearborn a few months ago. My soil is sandy, and I've discovered that in some places I can bog down if the plow is set too deep. I just lift it a little bit and keep going.
/ ground plow #4
Back when I was a young lad, dad had a 32 HP Massey Ferguson 50. (Yeah, yeah....I know, when I was young they hadn't even invented dirt yet, muchless a plow /forums/images/graemlins/tongue.gif) We pulled 2X12" plows with it. In some ground, that's all the old MF wanted. Of course, we have clay that's like concrete at times.
One issue would be WEIGHT. That old Massey hit the scales at 4300LBS, ballasted and field ready. It would do some serious spinning if conditions weren't just right.
It's hard to compare tractors of yesteryear against today. One thing is, those old tractors were designed to pull a plow. Even utility tractors back then were counted on to be pulling a plow. Todays tractors are designed with about everything EXCEPT heavy tillage in mind.
Also, consider what tires you are running. R-1's are OK, but AG tires work BETTER for plowing.
/ ground plow
Thanks for the help guys! I want to till a small garden. I'd like to get a few implements to play with. Thanks again for the replies. /forums/images/graemlins/smile.gif
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2013 Ford Flex SUV (A64557)
2013 Ford Flex SUV...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
