Ground Hogs
   / Ground Hogs #61
Give 'em a case of fatal lead poisoning with a 12 gauge shot gun loaded with 00 buckshot. Worked for me.
00 buck seems bit of overkill for a groundhog. I would think 4 shot would be more than enough. Personally, I would be more likely to use the .22-250 or a 9mm.
   / Ground Hogs #62
A conabear on each end of a 8 -12 inch corrugated pipe works great! Put pipe out where they can use for security, then put traps on each end! Found this out after watching one use culvert to travel. Went in and I put trap at one ent and blocks at other end. Waited and only had 20 minute wait till I heard the whack! Problem solved! Results may vary.
   / Ground Hogs #63
I use a 12 gauge. If they hide or are too near a structure, I have the wife flush them out into an open area.
My mother was doing that many years ago for a chuck who had gone into the garage, as my father waited outside with his trusty 16. She moved the snowplow and dropped it onto Chuck’s head, killing him.
   / Ground Hogs #64
Whew... for a minute I thought this was going to be a tragic story...
Thank God it was only the ground hog that saw it's demise... 🤣🤣🤣
   / Ground Hogs #65
Put your trap in a heavy black trash bag. Then a concrete block on top. That's what the county skunk catcher does and it has worked for me.
So far this year I have caught four baby skunks. They are still in traps way back in the sticks. Trapped one adult and one baby possum. Both were let go but it took four hours until the adult figured out he was free. S-I-L got a coon but it tore the trap up and got out. He also had a run in with an armadillo. Was trying new ammo out in my little Seecamp when something squeaked behind me. I thought it was a weasel but nephew said it was probably a mink. Didn't know they were around here. Anyway we stared at each other from about ten feet until it got bored and trotted off. Deer are so thick around here people are begging somebody to hunt on their property to thin them out. Rabbits are making a comeback and wife and I have both had close calls with wild turkeys while driving. Coyotes howling every night and have seen fox hunting behind my house.
I am 68 and there is more wild game around in Western Kentucky than I have ever seen.
RSKY
   / Ground Hogs #66
Ground hogs can cause a lot of trouble in a field. On the farm we just sold they had dug burrows in low areas in the fields and as it rained they washed out into small gulleys. Brother in law didn't see one of those gulleys and hit it wide open with the right front on a 1206 International. Broke the front wheel off and hurt him where the steering wheel caught his stomach. I put big hay bales in them after that. We had so much trouble with them back in the 80's that another b-i-l put a scope on my deceased dad's Remington 22 and my kind hearted mother used it to kill 15-20 one summer.
RSKY
   / Ground Hogs #67
Tough to hit em' on the run with a rifle or pistol. I'll use a .22 mag at long range if they hold still long enough. Most I see now are close to the house and the 12 gauge with #4's works best.
   / Ground Hogs #68
220 conibear has worked so well for me. I didnt even know I had so many ground hogs before this year. I'm up to 6 this year..I only ever saw 1-2.
   / Ground Hogs #69
They aren't very forgiving though. A good 1 3/4 coilspring will accomplish the same thing, and you still have the chance to release a nontarget animal.
That's what I found scary about working in Vermont. Apparently they can set a 330 on the river banks; or at least they do it anyways.
I was working for the landowner, bringing my dog with me; and it would not have been good if she'd gotten into one.
   / Ground Hogs #70
I was reading from the log I keep on the property the other day. There WAS a family of ground hogs - down in the valley. The first weeks or so, when we came down from AK, my son wiped them out with his scoped 22. Replacements never came to the valley.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
Toro Z Master Mower (A50324)
Toro Z Master...
1990 KENWORTH T800 FUEL AND LUBE TRUCK(INOPERABLE) (A50854)
1990 KENWORTH T800...
