Ground compaction
   / Ground compaction #1
tsperry88
Kubota B7610
If you don't want to read my long post, the basic question is this. What tears up wooded property the least, as far as soil compaction and rutting. A lightweight tracked skid steer with 3psi of ground pressure or something like a 1025R that probably has higher ground pressure.
I have 4 acres of woods that have been attacked by vines for an extremely long time. They have killed a lot of trees, leaving the woods less dense with an unusually large amount of fallen dead trees and branches.
I would like to clean it up and hit the whole area with a brush mower. My brother has a T770 skid that I have had in my possession for a few months. I avoid the woods with it, as it just ruts the soft ground up. It's ground pressure is just over 4psi, which doesn't sound bad. My Kubota B7610 probably has higher ground pressure due to less contact area, but seems to compact the woods less. I havnt spend much time in the the woods with either machine.
I have a few options. Use the skid and tear the crap out of the place. It's a 10.5k machine + and 1.5k grapple.
I could rent an RSV RC30 for a week. That machine has 3psi of ground pressure and is 1/3 the size and weight, but I don't know if it will make that much difference.
The last option and one I have been thinking the hardest about, is replacing my Kubota with 2 tractors. A good old farm tractor for pulling driveway implements and a Deere 1025R with turf tires for property chores and grapple work.
   / Ground compaction #2
You will probably want the low ground pressure tracked machine
   / Ground compaction #3
By the sounds you have answer your own question.
   / Ground compaction
Not really. I know the answer from a spec sheet. In the real world, what would tear up my woods less.
From the net:
When I ask users why they have tracks, the number one response I get is, “I want to get rid of compaction and the track has a much larger footprint area.” While it is true the total footprint area of a track is larger than a tire, the weight of the machine is not equally distributed under the track. When measuring the contact pressure of the track system, there are pressure spikes under each one of the boggy wheels. In wet or moist soils, the soil is damaged by the highest contact pressures, which would be under those boggy wheels. Firestone Ag has conducted studies on soil contact pressures on two and four track systems and wheeled tractors and has published technical papers with the American Society of Agricultural and Biological Engineers (ASABE). The results show:
  • If the inflation pressure of the tires is less than 20 psi, tires transmit less contact pressure to the soil compared to tracks.
  • From 20 to 35 psi, the tracks and wheel systems were comparable.
  • If the inflation pressure of the tires are above 35 psi, the track system had lower contact pressure than the tires.
However, there is still the perception that tracks reduce soil compaction when compared to tires, in all situations. What we have heard, anecdotally, is that the absence of a rut in the field means there must be no compaction. In wet soils, it does not matter which system is being used — compaction occurs with or without ruts. The rutting is a function on how the wheel and track system operate differently.
   / Ground compaction #5
I have cleared six acres of Florida jungle over seven years creating a lovely meadow, with Rotundfolia grape vines and wild, climbing rose the worst vines removed.
Soil compaction has never been an issue. I have R4/industrial tires inflated with air.
Many times I have tried to pull a 6" grape vine out of a tall Oak and rather than the vine coming down, the rear of my 5,400 pound operating weight tractor came off the ground, eliminating traction. Fortunately, grape vines deteriorate fast once cut and fall out of the trees in two, sometimes three years.
" My brother has a T770 skid steer. It's a 10.5k machine + and 1.5k grapple."
The perfect machine for your application.
A Ratchet Rake attached to your bucket is extremely helpful as two rows of teeth will hold vines, allowing you to pull vines out of trees from the tractor seat. Chain to the tractor rear/center drawbar with a slip hook on the end is necessary for the largest vines.
A Bucket Spade exhumes wild rose corms with one, two or three stabs.
   / Ground compaction #7
I think that the tracks can cause some damage from what is called "berming" which results from turning in soft ground conditions. Also, i question to what extend lower tire pressure reduces compaction, Yes, the plate area tends to increase as tire PSI is reduced but the tractor weighs the same regardless of tire PSI.
Edit: Looks like I was posting same time as Egon above. Yes, PSI in tire pressure and PSI in ground pressure are two difference animals.
   / Ground compaction #9
It's not just about (average) ground contact pressure though. Think about how you turn on a skid steer..... by ripping the track sideways. If your goal is minimal ground disturbance, you're much better off with a lightweight tractor with tires that ROLL and steer. Unless you only drive in exactly straight lines forward and backwards with the tracked skid, you're going to rip out all the ground cover and churn the topsoil.
   / Ground compaction #10
How about ground tearing when turning with a tracked vehicle? Doesn't it damage the ground more than wheels with differentials?
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A51039)
2016 Ottawa Yard...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
