Groaning/whining sound from rear lift(John Deere 3320)
   / Groaning/whining sound from rear lift(John Deere 3320) #1
foodplot123
Hello tractor lovers, I have a J.D. 3320, when i use my rear lift it makes a groaning sound when i pick up and when i put my hand on the hydraulic line that comes from the pump under the seat you can feel it moving,like air is in the line, and sometimes i'll leave a boxblade lifted for awhile and come back to the tractor and start it up(while the lift is still in the up position) and you can hear it for a long ways away, very loud, does anyone know what the problem might be ,thanks, foodplot123.
   / Groaning/whining sound from rear lift(John Deere 3320) #2
Maybe the relief valve. If you drop the 3pt lift a little does the sound go away. Is the lift valve hot. A stuck relief valve will heat things up a bit.
thanks j_J ,well it does it hot or cold ,everytime i lift, not in the down position
   / Groaning/whining sound from rear lift(John Deere 3320) #4
There is no "pump under the seat" on a JD 3320. Or "behind" it either.
there's a hydraulic line kind of behind and under the seat ,thats the one that you can feel the chatter in. and it comes from some type of pump under the seat area on the left side. i guess it's the pump for the lift.
   / Groaning/whining sound from rear lift(John Deere 3320) #6
The line is probably the supply line to the lift. It comes throught the SCV just to the right and into the rockshaft (the lift) just to the left.
Run your rate of drop valve in and out a few times see if that helps.
OK COCRE I"LL TRY THAT , THANKS A BUNCH FRIEND.FOODPLOT123
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
1992 SYLVAN 20' PONTOON BOAT (A51247)
1992 SYLVAN 20'...
RCcar RC-G2.0 Electric Golf Cart, New! (A52384)
RCcar RC-G2.0...
2023 AGT Topcat Mulching Head (A51573)
2023 AGT Topcat...
