Grinding when Turning
/ Grinding when Turning #21
Interesting review, but as usual with lubricants there is no measurement of wear on one product versus another.
When I put the Super Lube on my scissors, after about 10 to 20 operations the scissors were sticking again. With the Du Pont Lube I cycled them about 80 times and they worked fine. I quit cycling at the time and quit using Super Lube.
Hey Bob,
That's a good 'real-world' test. So, you're using the 'thicker' of the two lubes? And you like it? The biggest thing, in my experience is that Super-Lube collects all kinds of dirt and grass during PT operation. I'd LOVE to move to something that just doesn't do that. I have to believe that when dirt gets into the joint it has to make it wear faster. If we can use a product that a) removes dirt and water (e.g. via solvent flushing action) and b) leaves a tough lubricant and c) doesn't attract contaminants, then it would be ideal. It seems that this might the ticket.
I see my local Lowe's has the lighter 'multi-use' Dupont spray in stock. I'll have to check with Ace and TrueValue.
-Rob :)
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
