Grinding when putting in gear
   / Grinding when putting in gear #1
jas155
De Soto
Satoh S650G
Hello everyone. I am new to the forum, but have search quite extensively and come up with very little. I am currently looking at a Satoh S650G tractor to buy. The guy seems to be honest but was wondering if anyone has seen this. When trying to put the tractor in gear it grinds hard and when switching to high or low it does the same. I checked the fluid for the transmission and it is low, but I am not sure that is the problem. He tells me that the clutch has been replaced by the previous owner. This is the only thing i can see wrong with the tractor. Any help would be appreciated, thanks in advance.
   / Grinding when putting in gear #2
No expert here, but I suspect it is the clutch. Maybe it just needs adjustment.
   / Grinding when putting in gear #3
If anything like its successor the Mitsubishi*, the gears are not synchronized so shifting cannot be done in motion.
*most probably the same transmission.
I was shifting it without it moving at all. How do you adjust the clutch on these thing?
I have the repair manual and I see nothing on adjustments. I was hoping it was like a cable clutch and you just adjust it that way. But I see no way to do that.
   / Grinding when putting in gear #7
Sounds like a clutch problem to me as well. There is likely some mechanical adjustment in the clutch pedal linkage...but i'm unfamiliar with this model
   / Grinding when putting in gear #8
Try some googling if you don't get an answer here.
I have been, and not a whole lot of information about these tractors. Very strange.
   / Grinding when putting in gear #10
Seems like there should be some way to adjust the clutch.
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
Genie GTH-644 (A50490)
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
