Grinding tranny
   / Grinding tranny #1
skeezeck
Hello. I'm new and got my first tractor.
Massey 1020 gear shift.
When I press in the clutch I can't get it in gear without grinding. I put in gear when it's off then start the tractor with the clutch depressed and tractor and engages normally when I let it out. But if I take it out of gear. I'm back to grinding.
Need help please.
   / Grinding tranny #2
Need help please.
Lower your RPM's then try engaging the gears.
   / Grinding tranny #3
Most older tractor transmissions are non-synchro, and must be shifted while stopped.
If you're unable to get the gear to engage properly when stopped, I'm wondering if the clutch is adjusted properly. Perhaps it is dragging just slightly, or you aren't getting it fully depressed.
   / Grinding tranny #4
Both previous posts have given good advice. High RPMs or trying to shift on the move with an unsyc will cause the gears to grind. If it's an older tractor it probably has a mechanical clutch instead of hydraulic. Usually there is a threaded rod somewhere on the linkage to increase the travel to get the clutch to separate from the flywheel. If you have to floor the clutch pedal to get it disengage than you probably need to adjust some linkage.
   / Grinding tranny #5
On my 1020 it will grind if not at a complete stop or the rpm to high. If your using the foot throttel make sure is returns the rpm back to 900 rpm idel speed. Mine does not always return and I need to give it a little bump with my foot from below.
   / Grinding tranny
I did all the above. Went to pull it in the garage and seemed like it just slipped. I pulled it apart and there seemed like there was a decent amount of clutch on the disc. But the was a clip broke on the pressure plate assembly. It was under the bolt holding the pressure plate and the housing. I'm kinda confused.
But I do appreciate the help.
   / Grinding tranny #7
I had a problem with the clutch in my 265 Massey. The problem was, it was hard to go in gear from sitting still with the engine idled all the way down. I would have to select the gear I wanted and start in and then bump the high/low shifter in gear. I tried adjusting the clutch and that helped. then shortly after that I went out across the field and went to stop and clutched the tractor and it did not stop. WHOA! I got it back to the barn and went to work on it.
I broke it in half and come to find out one of the fingers on the clutch was broken and the piece was wedged in pressure plate and was not letting the clutch fully disengage. I replaced the clutch and all the parts associated with it and that took care of that.
   / Grinding tranny
I'm going to have the flywheel refaced and all new clutch parts. I notice some pics of the clutches have springs and some don't. Is one better than others?
   / Grinding tranny #9
Essentially all automotive clutches have springs. I think the idea is to ease the impact on the drivetrain from releasing the clutch. I've torn the springs out of 2 or 3 clutches over the years, causing the clutch to lock up.
I'm not sure about tractors, but I might consider one without springs. They should be built sturdier (no internal rotation), and I wouldn't loose the springs.
   / Grinding tranny
Thanks for the info. Sent the flywheel to the grinding shop and just waiting on the parts. Hopefully this will fix'er.
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2004 Wabash National 28ft Dry Van Trailer (A51692)
2004 Wabash...
1999 MadVac 101-D Riding Compact Debris Vacuum (A51691)
1999 MadVac 101-D...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
