Grillo, BCS and synchronized PTO
   / Grillo, BCS and synchronized PTO #1
jcraftenworth
Hawley, MN
Ford 9n, BCS 737
Read a thread earlier where Joel mentioned older BCS units have or can have a synchronized PTO for the 4 wheel drive trailer setups. I know on the current Grillo units it's a PTO synchronization kit that must be purchased. Is it the same for my BCS 737, or did the BCS units come with that synchronization factory installed?
That said, I envision a 3500 dollar 2 wheel tractor trailer far off on the horizon lol. But I like to feel that my tractor is among the elite, with a feature the current top end BCS 853 does NOT have! Helps me go to sleep with a smile on my face, that's all ;)
   / Grillo, BCS and synchronized PTO #2
Wouldn't you have a setting on the PTO control lever for synchronized speed? My Goldoni with powered trailer has three PTO settings-- synchronized, low speed, high speed. And it is clear when it is on synchro, because the PTO shaft is turning if not the same speed as the wheel axles, only some small multiple faster than them. e.g. there would be no possibility of using a rotovator when the PTO is set to synchro...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
