Grillo, BCS and synchronized PTO
   / Grillo, BCS and synchronized PTO #1
jcraftenworth
Hawley, MN
Ford 9n, BCS 737
Read a thread earlier where Joel mentioned older BCS units have or can have a synchronized PTO for the 4 wheel drive trailer setups. I know on the current Grillo units it's a PTO synchronization kit that must be purchased. Is it the same for my BCS 737, or did the BCS units come with that synchronization factory installed?
That said, I envision a 3500 dollar 2 wheel tractor trailer far off on the horizon lol. But I like to feel that my tractor is among the elite, with a feature the current top end BCS 853 does NOT have! Helps me go to sleep with a smile on my face, that's all ;)
   / Grillo, BCS and synchronized PTO #2
Wouldn't you have a setting on the PTO control lever for synchronized speed? My Goldoni with powered trailer has three PTO settings-- synchronized, low speed, high speed. And it is clear when it is on synchro, because the PTO shaft is turning if not the same speed as the wheel axles, only some small multiple faster than them. e.g. there would be no possibility of using a rotovator when the PTO is set to synchro...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2022 KMC 5610 LOT IDENTIFIER 197 (A53084)
2022 KMC 5610 LOT...
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
