Grill Guard
/ Grill Guard #1
tim250f
South Louisiana
Kubota L2800
I've been thinking about adding a grill guard to my L2800. The Kubota guard is almost $300, which is more than I'd like to spend. I found a dealer who sells an aftermarket version for just $185 made by a company called well-fit? Has anyone heard of this company and know if they have a web site where I can see pictures of this guard before I make the drive to purchase it? Any help would be appreciated. Thanks in advance.
/ Grill Guard #2
Tim, I don't have a pic of mine, but I fashioned one after one I saw on this site. If you do a search for grill guards, it should come up.
If you have to go to a welder to build one, it might not be cheaper than buying, but if you can weld, it's sure cheaper to build your own.
Best wishes,
Ron
/ Grill Guard #3
Tim,
On 10 / 03 of this year, Dargo made his own grill guard and suitcase weight setup, that in my opinion, is the best design that I have seen on TBN. In fact way better than anything Kubota offers. If you search "universal suitcase weights" it should pop up with pictures he posted. I think you will be impressed, I certainly was.
Good luck, Mark
/ Grill Guard #4
Grill guards are not that complicated. As long as the steel is 3/8" thick or better I don't see why the cheaper one wouldn't work as good as the factory setup.
I would think a welder could build one for you for $185 or less. The ones I have seen are just flat steel bent to fit the tractor and welded together.
Just be sure you measure the front frame on your tractor before you go to be sure it will fit and then go get it.
Bill Tolle
/ Grill Guard #6
Only a few things to consider when you layout your project..........like opening the hood, etc. etc.
Mark
/ Grill Guard #7
Hi Tim,
Did you get that aftermarket grill guard or build one yet?
Can you provide contact info on the outfit that makes them,
that is, "Well-fit"? I could use one for my L3650GST but would
prefer to spend less than the Kubota factory version costs.
Thanks for help.
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
PT 18' Dovetail Trailer (A64127)
PT 18' Dovetail...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
