Grill gromets
/ Grill gromets #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
I noticed that the large rubber gromits that the bottom pins on my DK35 grill fit into are no longer in place. Last time I went past my dealer, I picked up 2 new ones and installed them. I cut about 10 acres of hay and had to pull the grill off to clean the radiator screen and the gromits were missing again. Anyone else have a problem with this, I'd hate to have to buy them by the gross.
By the way, I was careful when I installed them to be sure they fit into the holes properly.
/ Grill gromets #2
Paul, sorry to hear of your problem. Any pics? Any way to drill grommet and grill pin and fasten together with a cotter pin? Or maybe install grommet, then a flat washer, then cotter pin to keep it in place. May not be possible, but pics might help understand better what problem you have.
/ Grill gromets #3
I don't know how the grommet are made, but can you glue them in? 3M Automotive trim glue will hold most things like that real well.
/ Grill gromets #4
I am nearing 1000 hours. Have not lost a gromet yet.
Only problems I have had so far have been a tachometer cable at around 500 hours and at 970 hours I had the plastic bowl that holds the fuel filter crack and begin to leak.
/ Grill gromets #5
:eek: :eek: :eek: 1000 hours!!!!
Almost time for a birthday party!!:D
/ Grill gromets
The 3m glue sounds like a good idea. I'll give it a try. Thanks.
/ Grill gromets #7
Not qute there yet. I think it was around 985+ last I looked.
2 or 3 more weeks and I will be there.
/ Grill gromets #8
Can also clean the area real good and use silicone as glue.
BTI
/ Grill gromets #9
I am interested to see if the "glue" thing works. My DK35 has the same problem...as well as recently replaceing the cracked fuel bowl in the middle of a pasture while baling hay!!
/ Grill gromets #10
The best way I have found was to use zip ties to keep them in place. I think that the glue might get dilluted with the battery acid so close.
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Ford 8600 (A64127)
Ford 8600 (A64127)
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
3012SFL (A61567)
3012SFL (A61567)
Deere 670G (A64126)
Deere 670G (A64126)
