Grill danger
/ Grill danger #1
patrick_g
Elite Member
South Central OK
Kubota Grand L-4610HSTC
Danger of grill brushes identified
Posted: 28 Mar 2012 11:28 AM PDT
Physicians have identified a number of cases of accidental ingestion of wire grill brush bristles that required endoscopic or surgical removal.
Lets be careful when brushing the goop off the grill as metal bristles might stick to grill and end up in your throat or worse.
Pat
/ Grill danger #2
A bit more info:
Seems that these cases resulted from the grills being cleaned with wire brushes and some wires broke off (and stuck to the grill). The wires adhered to the meat being (subsequently) cooked. When the meat was eaten, the wires were also ingested.
/ Grill danger #4
One more thing to worry about.
/ Grill danger
All it would take is one fragment of a wire bristle to stick to one little area less than hygienic and subsequently gets on/in a bite of food to ruin your day, get you sued, or worse.
Apparently it happens frequently enough to cause a mention in ScienceDaily news writeup.
Pat
/ Grill danger #8
Don't people CHEW anymore? It would have to be a vewy, vewy tiny piece of wire to escape my chomp-detection;-)
/ Grill danger #9
Use a stick and hold the meat over a wood fire. Solves all them problems!:thumbsup:
/ Grill danger #10
Sounds like an excuse not to clean the grill
/ Grill danger #11
I may be a minority here but have never used any type of wire brush to clean my grill grates. My method is to cut a groove in a flat section of foot long quarter inch thick oak, and scrape away. Thanks for the heads up on the danger of using a wire brush, I will pass it along to others.
/ Grill danger #12
I always preheat the grill to 600 degrees, pretty much nothing left on the grates but ash. Then a quick brush and everything's clean.
/ Grill danger #13
A bit more info:
Roy,
I was raised on fried meat and potatoes in a cast iron skillet. My mom scrubbed the skillets with Brillo steel mesh pads. No wonder I burp:D
/ Grill danger #14
Interesting! I use a stainless steel wire brush that I only use on the grill. Both the grill and the brush are about 15 years old and get used about twice a week. The brush is still in pretty good shape.
/ Grill danger #16
I only clean my grill with a brass brush once it's near cooking temp...And I check it for bristles...Never seen any so far...
/ Grill danger #17
I would not be surprised if the suspect grill brush was made in china since I've never heard of this happening before. The brass one I use is about 15 yr old and I only brush the grill after it's been burnt off and dry.
/ Grill danger #18
I bring a magnet when I buy BBQ brushes.
The ElCheepo's tend to be steel that is brass plated and they rust, get thin and brittle then bits and pieces break off.
REAL brass wont do that!
/ Grill danger #19
True...if I remember correctly, my brass brush wasn't anywhere near cheap.
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
7' Disc (A62613)
7' Disc (A62613)
3pt 7' Disc Harrow (A64127)
3pt 7' Disc Harrow...
