Grey Water Disposal
/ Grey Water Disposal #1
IHDiesel73L
We've been in our place almost a year now-150 year old farmhouse on acreage with lots of updates to various systems (electrical, heat, etc...), but when we bought it, it had a cesspool and no water treatment. As a condition of the sale the previous owner put in a brand new septic, pH balancer and water softener. At some point, (I'm guessing since the PO knew the cesspool was on borrowed time) the following waste lines were diverted into separate line which ran to daylight in a meadow about 20 yards from the house:
  • Washing machine
  • Kitchen sink
  • Dishwasher
  • Downstairs bathroom sink
  • Downstairs bathroom tub
  • Basement slop sink
  • pH balancer backwash
  • Softener backwash
  • Basement dehumidifier condensate
This of course was all tied back into the main waste line when the new septic was installed. The septic is a 1300 gallon two chamber tank with an effluent filter at the outlet, but since this is our "forever" house, we want to make sure that the septic has a good long life. Now, just to start things off, yes, I know that diverting grey water is not legal or code compliant in most places. However, I also know that lint, coffee grounds, and water treatment backwash salts and minerals are very bad for septic drainfields. As far as I'm concerned, septic drainfields should be reserved for dealing with poop and poop only. Obviously discharging human waste directly into the ground uncontrolled and untreated is not a good idea, but I fail to see the harm in discharging any of the things I listed above out into an open field. I live on quite a bit of acreage and I know for a fact that there is not another well (besides mine) within 1000' of the proposed area of disposal. That said, what is the best way to handle this? Drywell? Trench?
/ Grey Water Disposal #2
Research the requirments for your jurisdiction,everything you named except kitchen sink is often allowed to be drained onto surface. If surface disposal is forbidden,dry wells are usually forbbiden as well. It come's down to your local officials and how aggressively they inforce it. If I were in a corner and local officials weren't acting like the gestapo,I would install arobic treatment then distrubite with sprinklers.
I'm not going to post my jurisdiction, but I've read the regulations and know for a fact that grey water disposal anywhere other than a sewer or septic system is forbidden. As far as enforcement, it will only become an issue when the house is eventually sold, which, God willing, won't be until my wife and I are six feet under in our very own "zone of disposal." :p Even if we did find ourselves having to sell the house for some reason it would be easily put back to the way it was with a few fittings and some lengths of PVC. The County Health Department would be responsible for any type of enforcement, and the only way they find out about this type of stuff is when they are doing inspections for new installs or repairs, (not happening anytime even remotely soon) or when investigating complaints-Its not as if I'm looking to dump it onto my neighbor's lawn. I'm a 1/4 mile off of the road in the woods, so there is no one to see anything or to complain.
Interestingly, I just went back through my files and found the septic plan with our closing documents. In it, the engineer that designed the system specifically stated "Garbage disposals and water softening equipment shall NOT be discharged to this system." In doing a bit of research I found that I can buy a lint filter for the washing machine, which is my biggest worry (the system should be adequately sized to handle the water), but it sounds like I really need to get the water softener discharge out of there ASAP.
/ Grey Water Disposal #4
Personal what I would do is run a separate drain line out to a couple of dry wells with some stone around them, concrete covers on the dry wells and enjoy knowing that my septic system was going to do the job it was supposed to and my dry wells there job. If you wanted to add a septic tank before the dry wells and plan on having it pumped as necessary for solids. Maybe every few years.
Using a septic tank and dry wells could even meet rules.
/ Grey Water Disposal #5
If you think the septic is for poop and poop only I’d spend some time reading up on septic systems. The gray water isn’t going to “overload” a properly designed system and typically it’s beneficial to move the fluid through the system. I’d leave it as designed and find the next hobby to occupy your time and resources.
Under the state code a 4 bedroom system must be designed to handle 650 GPD. I used an online water usage calculator that pegged us at about 550 GPD for usage, but this doesn't take into account any water discharged to the system by the dehumidifier or the water treatment. Obviously as you said the system needs a certain amount of water to move effluent out to the field, but the biggest worry is moving effluent out to the field before enough solids have been settled out. I would feel a little better about that if I wasn't within less than 100 GPD of the design limit.
/ Grey Water Disposal #7
What is it about the salt in a water softener that is so awful for a septic system? Our house was built in 2004 with all drains connected to the septic system with mound and everything has been operating happily, at least as evidenced by the nearly 3 years we've lived here. The system has a filter between the two septic tanks which prevents solids from reaching tank 2 and the mound system. Our septic guy that has pumped the system several times has said it looks like everything is great.
Is the salt supposed to harm bacteria and make decomposition go too slowly? Not happening in our case.
Rob
/ Grey Water Disposal #8
As long as all bathroom fluids (sinks, tubs, showers) go into the system, you should have enough to keep it running. The rest (kitchen, laundry, etc.) aren't needed.
I think it has more to do with what happens when the highly concentrated brine makes it out to the drainfield. I've read about a couple of instances where the salts crusted around the effluent filter enough to clog it, so you can imagine what could be happening in the laterals. Here's an article that I would argue is rather inconclusive:
GWSofteners
- Center for Watershed Science and Education | UWSP
/ Grey Water Disposal #10
Septic systems in MS have aerator pumps. These have air plumbing that is resting on the bottom of the tank and the air bubbles keep the bacteria working and also aid in breaking down solids.
The discharge you see could be just run off from the system and not real grey water from the house.
There is septic treatments for bacteria.
Is there not a cover for the new system where you can see inside?
/ Grey Water Disposal #11
To do it legally you could have another soil test/site plan done to put in a grey water system; then if situations change you can sell without worrying about being in compliance.
/ Grey Water Disposal #12
... However, I also know that lint, coffee grounds, and water treatment backwash salts and minerals are very bad for septic drainfields.....
How do you know water softener backwash is bad for septic drainfields?
Do you know how many gallons of backwash your water softener generates?
Do you know how often your water softener re-generates?
Since your septic system is new, isn't there a filter on it to prevent lint and undigested paper products and such from getting to the drain field?
/ Grey Water Disposal #13
I asked the same question about the softener discharge a couple days ago. No answer yet.
Rob
/ Grey Water Disposal #14
When I had my house built they required a separate system for the washing machine. We had been living on the property in a mobile home for quite a while so we used the septic system for that for the washing machine and had a new system installed for the house.
Since our house was built we had to have the drain field replaced because my sister and wife planted a Crepe Myrtle tree on it and it was clogged with roots.
Your poop and any other solids are not supposed to make it to the drain field in a properly designed/working system. Solids should settle into the tank and be pumped out on a cycle. Cycles depend on use and are anywhere for 2 to 5 years.
/ Grey Water Disposal #15
A few years ago was reading about grey water systems. Basically anything that can contain feces, another word for poop, could not go into the grey water system. So including Diggin It list, would be laundry.
Also if you watch Top Gear, a used car contains feces.........
/ Grey Water Disposal #16
The salt from the softener has caused problems with systems with a pump (mound systems are popular around here due to the heavy clay). My inlaws had to replace their pump on a regular basis until they diverted the softener water to a drywell.
/ Grey Water Disposal #17
No problems:
How Do Water Softeners Affect Septic Systems? | Water-Right
No Problems:
GWSofteners
Problems, but easily resolved:
Just route the softener regen discharge directly to the drain field, skipping the septic, and that resolves any issues the might occur due to salt.
Water softener discharges do harm septic systems -- And the problem is easy to solve - WaterWorld
Bottom line is this...
A water softener shouldn't use any more water than, say, a washing machine, or a couple people showering.
It shouldn't regenerate on a timer. It should regenerate on demand.
Most people have never had their water tested, and have their water softeners set to use too much salt for their needs. Have the water tested and set the softener properly.
/ Grey Water Disposal #18
I occasionally stay with some friends when I'm in their town on business. I've mentioned a couple times that their system is turned up too high - I never feel rinsed no matter how long I'm under the shower after washing. He maintains it's at the right setting but he's never had the water tested (city water, not sure where he's getting the setting but it's not worth "proving" one way or another).
/ Grey Water Disposal #19
Not sure I follow. If a softener isn't doing enough to fully soften the water the water will still be hard and soapy water will feel 'sticky'. If the softener is set right it will fully soften the water and use only as much salt as needed (i.e. only regen when needed and not use more salt during the process than needed to clean the resin). If the system is set to regen too frequently or use more salt during regen then you waste salt and water, but the resulting softened water isn't any different. It's still fully softened - the softener can't do more than just remove all the minerals in the hard water. Perhaps what you were experiencing was their softener not being effective enough?
Rob
/ Grey Water Disposal #20
Yep. Soft water should feel just that... soft. You're skin should feel slick and smooth after a shower, and not sticky, or squeaky clean.
