bjr
Veteran Member
I have 50" Hinomoto Tiller I need to adapt the input shaft. I cannot get a fine spline adapter 1.150 x 16 to 1-3/6 x 6 spline and also don't have a slip clutch.
Here's what I was thinking, tell me what you think. I have a small yoke (cann't get anythine to match up to) with proper female splines that I will weld a stub 1-3/8 smooth stub to with a 3/8 hole for a shear bolt, grade five or less. Will this work or maybe I should go with a 1-1/2 smooth shaft with 1/2 shear bolt? Cost for the slip clutch as the extra length needed is a concern, that's why I thought a shear bolt rather than a extra slip clutch. Thanks. bjr
