Gresen 2712 M
/ Gresen 2712 M
Cool enough the fluid tank is within the 3” loader structure itself. I have no idea how much capacity it takes; I’m sure it’s quite a bit. (Lowest horizontal pipe in the picture) IMG_1330.jpg
/ Gresen 2712 M #22
25 GPM at 2500 PSI would take 44 HP. I would think 14 GPM would be plenty. Are you wanting to drive a hydraulic motor or just cylinders?
/ Gresen 2712 M
Well I’ve considered hydraulic driven wood chippers and stuff of the sort just so I don’t have to upgrade to a new tractor. Make the simple old tractor one that can handle any implement in the 45 HP range.
/ Gresen 2712 M #24
For reference on existing reservoir size: it takes approximately 33 inches of 3 inch pipe to hold one gallon
If you increase the pump size very much you will also potentially have to increase the hose sizes, valve size, reservoir size, etc..
/ Gresen 2712 M #25
There is a member on this forum that goes by Soundguy. He seems really knowledgeable about the old fords and is probably more familiar with these loaders.
Oldnslo is one of the better sources on hydraulics as well.
Looks like a fun project and look forward to seeing it finished!
/ Gresen 2712 M
Thanks for all the information. I know beginner questions can get annoying. You’ve got me on a good start for the hydraulic rebuild. Greatly appreciated.
/ Gresen 2712 M #27
Not annoying at all. There is a lot of options to get the same result. Just have to know exactly what you want to accomplish before you begin.
You can spend a lot of money fast and still not be happy, if you don't do plenty of research. We are glad to help. :thumbsup:
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2018 Case IH Maxxum 150 (A64911)
2018 Case IH...
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2026 Unused CID ITAKB72-SC 72in. Skid Steer Bucket Attachment (A66734)
2026 Unused CID...
2018 Deere 672GP (A64911)
2018 Deere 672GP...
