Gresen 2702 Power Beyond Port
   / Gresen 2702 Power Beyond Port #1
James Eric
My 2702 has a power beyond port that has a plug. Can I just remove the plug and add a hose or do I need a special plug for the power beyond?
Thanks,
James
   / Gresen 2702 Power Beyond Port #2
Thanks for the reply. How can I identify my setup?
   / Gresen 2702 Power Beyond Port #4
The 2702 is the casting number on the valve. Gresen was purchased by Parker Hannifan so you may have to contact one of their distributors.
Since valves and casting are made differently it is hard to tell you to just remove this plug and look for passages from here to here.
Roy
Thanks again. You both have been very helpful. I don't have a use for it now. I just wanted to keep my options open.
   / Gresen 2702 Power Beyond Port #6
Thanks for the PDF's.
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
