Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #1
jmsjolly
International 3500A
Hello everyone - thanks for coming together for this informational forum. As a rookie, I just broke my first hydraulic hose, and it is somewhat buried behind a couple other hoses. ALL of them are original to my 1975 International 3500A and they won't come off. I am soaking them with PB Blaster but it is not the blaster of old by far. Any other advice to break these guys loose?
James
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #2
Hello and welcome! I will leave your issue to the much more capable on the forums. I would love to see some pics of the machine! Maybe even a few of the hose situation would help others troubleshoot.
I will get back out there in the snow today. the local NAPA assures me they can make the replacement but I have to bring the blowout. I thought "easy enough" but then discovered that Superman was the assembler of my unit.
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #4
James
Get, and use, a spray can of "Kroil" (kinda pricey), and keep the PB Blaster for something important..like lubricating your house door hinges.
Assuming you can reach the fittings, try using a long cold chisel with 2lb. hammer, to start moving each hose nut.
Last year I had to replace ALL my 1970 Ford 3400 BH hoses, and the chisel method to start the nuts off was what I did.
Had to use the chisel method to put the new hose nuts on also. That left a chisel mark in each new nut, but the job is done, and none of the connections leak.
Many thanks. I used to remember that PB Blaster showed you how it dissolved a styrofoam cup and was orange - now it looks and kind of smells like WD40. The good news in this is that my delay showed me leak in a separate hose than I thought the leak originated. And I got it loose and replaced!
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #6
Welcome to the forum! It looks like you're already finding some good advice around here. :)
Yes indeed I am! Very helpful.
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #8
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
Thanks bud - man this internet thing goes quite a way! It's a great site. Now, since you are from Down Under, I cannot imagine jumping into my 1975 backhoe after having it sit for a few weeks and not encounter some sort of deadly spider or snake or something like I did up here in the northeast US with a common field mouse. He had beady little eyes, and he was acting all suspicious but nothing like the browns and tiger snakes you guys have... :)
   / Greetings fro Upstate NY - A backhoe rookie! 1975 International 3500A #10
Welcome to the forum.
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2021 Vermeer Wood Chipper (A51573)
2021 Vermeer Wood...
2021 JOHN DEERE 7R230 LOT NUMBER 208 (A53084)
2021 JOHN DEERE...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
