Green Manure..cover crop
   / Green Manure..cover crop #1
theboman
Grayson, KY
Kubota B7500 HST
What should I use as a cover crop on my garden and when is the best time to sew? etc etc etc.
The corn and beans have been picked. Still enough tomatos for a small city. The cucumbers have pickled out. The squash & pumpkins have pretty much decided they are no longer needed in this dry weather and looks like the vines are dying.
I've learned a lot. 1.5 lbs of green beans is a lot, especially when they all come in at the same time! 30 tomato plants are about 15 more than I need. 1 lb of corn wasn't enuff.
   / Green Manure..cover crop #2
Here in NE Missouri, I've been using winter wheat and winter rye. There are cold hardy so they can be planted in late summer - early fall. It sure has made a difference in my garden soil. I usually turn it in sometime in April. (Of course, now I don't have to borrow my neighbors tiller. hehehe)
Jim
   / Green Manure..cover crop #3
I use winter Rye and put it in after the first frost. This year the garden was a total bust on the front range of Colorado. NO rain and even the well is not recovering like we need it to. Have bought water for the house 3 times already! Pull up or till in your stalks after the 1st frost and then sew in your Rye. Let it go all winter and into the spring. Till up only what you want to plant right then and let the rest go (but not to seed) and till it up as needed. It will bring up nutrients from deep in the soil and when you till it under the top soil gets fed. Next year think about staggering your plantings so you don't get hit at once with everything. You can get spinache and lettuce in the fall untill it snows!
   / Green Manure..cover crop #4
Winter rye is the cover crop of choice for the midwest. To add a little twist to the mix you might want to blend in some hairy vetch with the winter rye seed before sowing. They are very compatible. The hairy vetch, being a legume will fix nitrogen into the soil which will be readilly available to whatever you plant in the spring. Definitely till in cover crop before it goes to seed so it doesn't become a nuisance.
   / Green Manure..cover crop #5
Here in the Northeast, NJ, I use buckwheat until the first frost and then use winter rye for the winter. The buckwheat is grown until it produces white flowers, when it does, I till it under, wait a week for it to break down and then plant another crop until the frost hits. We usually take one row, 4’ by 50’ out of production each year, so I do this all summer long until fall. Can get 3-5 plantings until the frost. A 50 lbs bag is about $25.
Tom
   / Green Manure..cover crop #6
Well, I planted Hairy Vetch one year, it came in thick and lush, and tilled under easy. Unfortunately, it came back in the spring, and ended up in all my flower beds...year after year. I'd try winter rye.
- Patrick W.
   / Green Manure..cover crop #7
Dumb question but is winter rye the same as annual rye grass? thanks. bw
   / Green Manure..cover crop #8
I beleive annual rye grass is one of the grasses used for lawns. Its not the same as winter rye.
Egon
   / Green Manure..cover crop #9
I could be wrong, annual rye and winter rye are the same thing. Often used for a cover crop and temporary ground cover. Perinial rye is a lawn grass used in some areas. Like all pernials it comes back from roots, rhzomes etc each year. It is a cool season grass similar in nature to lawn fescues. There are several new varieties of Pernial rye that are much imporved and are excellent for lawns. J
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
Tires (A50322)
Tires (A50322)
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
