green flood
   / green flood #1
cubscout
Stillwater, MN
1982 Cub Cadet 1282, John Deere x324, Kubota 7510, Farmall B
I own a 2006 x324. On cold starts the tractor will run for 30 seconds or so and then flood out. On restarts the fuel will go through the engine and the exhaust and leave a big puddle on the ground. Sometimes on restarts it will run on one cylinder and billow out white smoke, yet sometimes it will restart perfectly.
The problem is worse on colder days or when the tractor has not been started for several days.
The dealer can't figure this one out.
   / green flood #2
I believe you have a v-twin Kawasaki. My LT180 used to stutter a little at idle. The pilot jet in the carb has such a small hole that it is easy to get clogged by debris or bad gas. You could also have a float that is sticking. But the fact that cold weather enhances this problem, I'd guess that you need to regulate the choke a bit longer. After firing off, backoff the choke incrementally, not all at once and let her warm up a minute or three at a bit above idle.
If this doesn't help, try cleaning the carburetor.
   / green flood #3
You might get more informed responses in the lawn and garden section. There are guys there that know these small engines, their wives and their kids, by name.
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
1994 Utility Trailer MFG Co. VS2R Van Trailer (A53117)
1994 Utility...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2006 FORD F-250 (A53843)
2006 FORD F-250...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
