Green connectors? L3240
   / Green connectors? L3240 #1
mgamber
Houston, TX
Kubota L3240
Does anyone know what the 3 green connectors are that are on the right hand side of the seat? Are these aux light connectors?
   / Green connectors? L3240 #2
On my L3130 GST by the right side of the seat have two gray four pin connectors with plugs. After removing plugs and disconnecting the GST ECU you plug those together to put tractor into first gear to move it incase the GST fails. Have another two pin green connector with yellow and black wires and that should be for the optional work light and has a 7.5 amp fuse on it according to shop manual. Some place on the tractor there should also be a 4 pin "Check" connector. Not sure what they changed on the 40 series from the 30 but should be close.
David Kb7uns
   / Green connectors? L3240 #3
My L4240 HST has similar connectors, can't remember if just two or three. I do not know if they were intended for lights but I did use one to power a relay that i use to control back lights. Mine only have power when the ignition switch is on.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
