Green Board or Durock?
   / Green Board or Durock? #1
goeduck
Super Member
Kitsap, WA
Kubota, Massey, Iseki
I have a rental that I bought a year and a half ago that has had a nagging mold problem in the shower ceiling. The previous owner did a partial DIY reroof which created leaks above the master bedroom and bath when the wind blew which may have been contributing to the problem. I hired a roofer to re-roof that area and that did fix a leak in the bedroom, so I have to believe there are no leaks above the bathroom, although the bath is way up against the eave and very hard to get at to be 100% positive. After the roofing, I waited a month and bleached, put on a mold killer, mold primer and painted with a mold resistant paint. Two months later the mold is showing through. The tenant is great, but they are military and very detail oriented. So the slight mold bugs them. I want to put an end to the problem and plan to replace the ceiling drywall. The house is vintage 1950, so it probably has regular sheetrock on the ceiling. My question to all is should I use green board, Durock or some other alternative if I want to completely get rid of the problem forever. It is just a standard full bath, so material cost difference is minor.
   / Green Board or Durock? #2
I don’t think it’s a underlying board problem if both start mildew free.
I use cultured marble for bath and shower surrounds… leak proof and easy clean up.
Also for ceilings over showers.
For painted surfaces Zinsser Perma-White with Zinsser Mold Killing Primer is a one two punch.
These products have eliminated mold issues in my rentals.
Of course ventilation such as a exhaust fan is great if used.
Same treatment for exterior wall closets because many renters stuff closets so tight air can’t circulate.
At $45 a gallon it’s not cheap but does the job.
   / Green Board or Durock? #3
Did you replace the sheetrock or just bleach and paint?
Pull the sheetrock and clean/bleach the area of the attic/roof above it, then re-sheet with Greenboard. You should probably do at least part way down the wall as well.
Also, do you have a good bathroom fan that is not blocked or just blowing into the attic? It should blow all the way to through an outside wall, not a roof vent that can leak.
Since you had a leak or 2 for awhile, you should also look at the attic and underside of the roof for any other damage and mold.
That is the primer that I used, but I used a Benjamin Moore mold resistant paint. Good to know about Zinsser Perma-White.
   / Green Board or Durock? #5
That is the primer that I used, but I used a Benjamon Moore mold resistant paint. Good to know
I had reoccurring issues in rentals which can become a big problem depending on resident lifestyle.
Started using 2 coats perma white 40 years ago… they even have an exterior paint but could not get it easily in California…
I’m hoping the formula hasn’t changed.
I have done entire rentals with it for insurance.
I just bleached and painted, trying to save the effort of replacing the underlying board. The bath fan does blow out the gable vent. The underside of the roof looks fine but the top side of the sheetrock is somewhat grey. The previous owner roofed that area starting at the top and worked his way to the fascia for whatever reason. He also did the same thing with the tar paper. To do that he had to nail up high on the shingles and not on the nailing strip. So when the wind blew from the west (unusual in that area), the roofer identified a few shingle areas that he believed were lifting in the wind which would allow rain to blow under and then get between the shingles and tar paper. Since the wind rarely blew in that direction, the roof underside looks good, but the top of the sheetrock could have had moisture sitting on it for a while.
   / Green Board or Durock? #7
@goeduck I see a couple of issues here.
Speaking as a former roofer, roofing from the top down is not a reasonable way to roof, and it is absolutely going to be prone to wind damage and water penetration. I think that you are likely playing roulette with the roof.
I don't know if the roof is the source of the problem, but it won't help the longevity of the house.
Overpainting surfaces that have had mold is tough, because the spores for molds are so tough. I use TSP and bleach, but for more than mild mold, I think it is a rip out and replace. While anti-mildew paint and additives help, I think it is asking a lot, and perhaps too much give where you are located.
If it were me, I would start would increasing the fan size, then remove the problematic sheetrock, and start over. You can get fans with humidity sensors that will continue to run u til the humidity drops below a set level. Given the history, I would certainly use a mildew resistant primer and paint if you go with sheetrock, but again, given the history, if it were me, I would go for an enclosed shower stall with 100% composite surfaces.
All the best,
Peter
The previous DIY owner did that, I had that area reroofed by a roofing contractor and he started at the bottom. Both my home inspector and I missed that that portion of the house was re-roofed when I bought it. I usually will not buy any house with significant DIY. I am guessing they had some damage from tree branches and were cutting corners on the repair.
I agree that ripping the old ceiling board out and replacing with new board is the way to go.
   / Green Board or Durock? #9
The previous DIY owner did that, I had that are reroofed by a roofing contractor and he started at the top.
Wow. I've never seen that. What is the roofing material?
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Scag Tiger Cat Zeroturn (RUNS) (A50774)
Scag Tiger Cat...
Kubota L3130 Compact Tractor (RIDE AND DRIVE) (A50774)
Kubota L3130...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
