Great new knife sharpener.
/ Great new knife sharpener. #1
Kays Supply
Southern Illinois
Iseki TA 207
FYI all that might be interested. I just got my set of paper wheel knife sharpeners from Grizzly tool. One is a carbide grit covered wheel and the other a paper wheel you put rouge on to polish the final edge. They work GREAT. I can put a razor edge on just about any knife in a few seconds. I have done everybody's knife I know.
/ Great new knife sharpener. #2
How about a model number?
/ Great new knife sharpener. #3
I've read those things work great. Where did you get them from?
Grizzly Industrial 1-800-523-4777 Model G5937 $33.95 . I picked up a cheap table top grinder at Lowes. The wheels are 8" but can fit a 6" grinder if you take the covers off. This is my second set. I wore the other set to a nub. They will send you a great wish book / catalog with your order.
/ Great new knife sharpener. #5
Thanks for the info.
/ Great new knife sharpener. #8
Many years ago, there was a fellow at a flea market who had what appeared to be the same paper wheel. At that time, he was sharpening knives and charging $1 per blade.
If they made that kit in 6" size as well as 8", I'd buy it, but I don't want to remove the guards and put an 8" wheel on my 6" bench grinder.
/ Great new knife sharpener. #9
On e of my hobbies is woodcarving (see pictures) and I use a felt wheel with compond to put a final edge on my tools. One thing that makes it easier is to rig up the grinder so the wheel turns away from you and not toward you. This way you can see the edge you are working on without the chance of getting the edge caught in the wheel and sending the tool flying.
/ Great new knife sharpener. #10
that's a good idea....
you could buy a cheap motor at the flea market, buy one of those little adapter for like $5 at the hardware store..
then just set the whole thing in a direction that the wheel would turn away from you....
pretty slick.....
more expensive but for sharpening wood lathe tools, those slow turning wet stones work great.......i think grizzly is making one now.....
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
HARDEE DITCH BANK MOWER (A63745)
HARDEE DITCH BANK...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
karcher pressure washer (A61567)
karcher pressure...
