greasing the loader
   / greasing the loader #1
rthrbhntg
Delaware Co NY
Kubota MX5100
This might be a silly question but I'm a novice tractor guy and need to lubricate the loader for the first time on a Kubota MX5100. Read the instructions but it only tells you where to lubricte not how. I have the grease and the grease gun ready to go but how do I get the grease where it needs to go? Seems like a tight fit where all the movement takes place. Any help appreciated.
   / greasing the loader #2
Push the tip of the grease gun on the Zerk fitting and pump it until you can just barely see grease come out around the pins.
An exception is the Zerks by the wheels. Just 2 or 3 squirts are fine. They have sealed bearings in most cases.
Then comes the fun...getting the tip off of the Zerk fittings. Most of the time a simple bend of the tip/pipe will do it. But sometimes the Zerk is deep in a socket that protects it. Some use a screwdriver to pry it off, others unscrew the tip which releases the locking mechanism.
When you get tired of the hassle of greasing every 10 hours you may want to consider a air-operated grease gun if you have an air compressor.
Buy.com - Lincoln Industrial - Air Operated Grease Gun
Check eBay for the best prices.
   / greasing the loader #3
It helps to get a flexible hose for your grease gun. If your gun has the rigid pipe, that may be why it seems tight in some areas to use the gun.
   / greasing the loader #4
and also raise your loader so you dont have downward pressure on your zerks.
   / greasing the loader #5
You may find that different grease fittings require the loader to be in different positions for access. When greasing my FEL or excavator, I have the machine running so I can access all the different fittings.
   / greasing the loader #6
I put a hose on my grease gun then found it takes three hands to grease anything. One to hold the tip on the fitting, and two to operate the grease gun. So I bought a pistaol grip style grease gun and problem solved.
   / greasing the loader #7
Did the same thing. Got a practically new lever style that gets little use compared to pistol grip one.
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2015 KENWORTH T800 KILL TRUCK BOBTAIL (A53843)
2015 KENWORTH T800...
CAT Skid Steer (A50322)
CAT Skid Steer...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
