Mowing Greasing finish mower spindles
/ Greasing finish mower spindles #1
jdp
Southern Pines, NC
Kubota B 2320
Just got a used King Kutter 5' rear discharge finish mower. How much grease do you put in when greasing mower spindles. Are they sealed, so you put in a set amount? Should I see grease exiting bottom of spindle above blade? Manual just says to grease- no guidance.
thanks
/ Greasing finish mower spindles #2
My spindles are sealed, and I have not seen any mowing decks with unsealed spindles. I grease (3-5 shots) mine at the beginning of the season and when I sharpen the blades, usually once a season.
/ Greasing finish mower spindles #3
The owner's manual for my 7 foot Woods calls for 1 pump every 12 hours. Gotta wonder where it goes. Not sure if they are sealed or not.
/ Greasing finish mower spindles #4
Sealed spindles don't usually have a zerk-
If you are able to push grease in, there has to be a way for it to seep out under pressure. I usually pump in till i see a little squeeze out, in my mind, that pushes out old grease, dirt and water and helps keep it from seeping in that way.
/ Greasing finish mower spindles #5
When I got my Craftsman 6000 ZTR mower, the mechanic said it had sealed bearing so I never really checked the spindles till the second year I had it. I then saw the zerks and began pumping grease into them till it came out. It took a tube and a half total for all 3 spindles to get grease to come out the spindle. That was beginning of this season and I havent greased them again. I figured that if it was good for a year without any grease, 20 oz ought to last for this mowing season. It takes me about an hour to mow and about once every two weeks so I dont think I put more than 12 hours per year. I no longer wash it off after use, just take a leaf blower and blow off the grass debris after use. Someone told me that washing allowed water to get into the bearings due to the way the spindles set in a depression in the deck, so I quit washing. Time will tell if this has any effect.
/ Greasing finish mower spindles #6
thanks
I bought the same mower this spring from TSC and I had the same question....shipped dry and no guidance. I pumped in red grease until I saw it oozing from under the pulley's. After a few use's I put in 1-2 more pumps to be safe. No issues so far.
/ Greasing finish mower spindles #7
I have an old Big Bee RFM. It says to grease it every 8 hours of use. That amounts to about every 3 mowings for me. I use an air powered grease gun and give each spindle about 5 pops of the trigger. I greased it once until grease came out from under the pulleys and it got slung all over the belt. So now I limit it to 5 pops with the grease gun.
Pooh Bear
/ Greasing finish mower spindles #8
I always wondered this myself. I seem to use mine about 2 hours at a time. I give each spindle 2 pumps before each use. If I was to mow 2 hr in the morning an again in the afternoon I probably would not grease it again that day.
/ Greasing finish mower spindles #9
I have always tried for one pump of grease for every hour of use-I am not saying that's right, but I have never replaced a spindle.
Will
/ Greasing finish mower spindles #10
My Woods PRD manual calls for greasing every 25 hours of use...
That would be approximately 2 times a year for me...
I grease every two cuttings...
My Land Pride RFM ran for 14 years...
My Woods has been running 6 years...
No spindle or bearing issues with either in 20 years of use...
Grease is cheap...
/ Greasing finish mower spindles #11
In all these posts there really is no consensus. I tired to find info on my B7800 mower deck a couple years ago and came up dry so I just grease every other use. But I sure would like to know what is the correct schedule. No mention in the owner's manuals or anything. Beats me but how come it's not addressed. Must be that Roswell thing.
Tennant M30 (A64127)
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
