Greasing Clutch and Brake Pedal (L3800)
   / Greasing Clutch and Brake Pedal (L3800) #1
Rail Dawg
The L3800 manual on the Lubricants, Fuel and Coolants chart lists the clutch pedal and brake pedal. Under Lubricants it says "Until Grease Overflows".
What do you think they mean? There isn't a Zerk fitting I assume. Do we just spray some grease on the moving parts?
Thanks.
   / Greasing Clutch and Brake Pedal (L3800) #2
Generally both will have zerk fittings, and you grease them until grease comes out.
   / Greasing Clutch and Brake Pedal (L3800) #3
There are two zerks on the center of the undercarriage. They are easy to see but you do have to crawl underneath. There is enough room to fit (just enough) under without having to jack anything up.
   / Greasing Clutch and Brake Pedal (L3800) #4
There are two zerks on the center of the undercarriage...
I think there are there's three (not two, left right and center) and they are normal grease zerks - easy to see the grease come out... just did mine last week. There are two for the front axle as well. I think I've mentioned this before... recheck the oil in the front axle since it's slow to seep in to the bottom.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2014 Bobcat 5600 Toolcat (RUNS) (A50774)
2014 Bobcat 5600...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
2008 Therma-Kleen Ultra 600 Propane Steam Cleaner (A50322)
2008 Therma-Kleen...
