Greasing a Massey Ferguson 135
   / Greasing a Massey Ferguson 135 #1
ArcherXC
Bronze Member
Swansea, SC
1965 Massey Ferguson 135
I am a new owner of a MF135. How do I tell if it needs greased? And if it does how do I know how much to grease it? One last question. What kind of grease do I use?
   / Greasing a Massey Ferguson 135 #2
You should grease all fittings every 10 hours. 1-3 squirts is all it will take if you keep after it. Up to 10 squirts if the joints are dry. Any automotive red grease should work. This is a case of regular intervals being better than fancy products.
Stop injecting grease after you see fresh grease squirting out of the joint. Wipe off the excess to keep it neat.
Do I grease the lift arms in the same manner? I heard that over greasing the lift arms can ruin the hydraulic fluid because the excess grease falls into the fluid tank.
   / Greasing a Massey Ferguson 135 #4
I doubt that grease would have any way of coming into contact with the hydraulic fluid. I would grease them the same way.
   / Greasing a Massey Ferguson 135 #5
Yep, grease 'em.
   / Greasing a Massey Ferguson 135 #6
After tearing down my 135 this couldnt be further from the truth. Take a look at the pictures in my thread about 135 hydraulics, I had to clean up at least 3-4 cans of old grease caked on to the pump. It was bad enough that the pump was not functioning correctly. So I would grease much more lightly on the lift arms.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
Stump Bucket (A50322)
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Toro Zero Turn (A50324)
Toro Zero Turn...
