Grease?
   / Grease? #11
Being the owner of several boats over the last few years. I think I may know why the label says not to mix different greases. With an Aluminum Outdrive on a boat the different materials can cause very bad corrosion of the whole outdrive. With an outdrive never us graphite based grease to lubricate the parts of drive that will be in the water.
ronh
   / Grease?
Ron,
You sure have it right with graphite grease and boats, but I think there are two different mechanisms working here.
The graphite is bad with respect to galvanic corrosion. Dissimilar metals that are separated in the galvanic series, (in the presence of an electrolyte, salt water or ionized water) form great little batteries that result in corrision of the least nobel metal. In your case it is the Aluminum alloy casting. That is why larger boats have sacrificial underwater Zinc plates (Zinc's) and outboards or I/O's have a Zinc rudder behind the prop which is also used to offset the prop walk of the engine. Zinc is one of the least noble of the metals followed by Aluminum and it's alloys. Graphite is the most noble of the metals found on boats.
The base mixing in the grease is a chemical reaction between incompatable bases that results in a reduction of their lubricating qualities. No electrolyte is necessary.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
iDrive TDS-2010H...
